Clearning Stock Brembo
Old Feb 23, 2009 | 08:57 PM
Frankieg35's Avatar
Wow ur right I could of sworn they told me 25 but it is 24
Old Feb 24, 2009 | 09:15 AM
ZeRo G35's Avatar
What spacers would I need for the front to fit?
I assume the rears are okay to fit?
Thanks!
Old Feb 24, 2009 | 01:30 PM
Frankieg35's Avatar
Either a 5 or 10 not sure but I know they have ones with studs on them already do a quick search u should find it..
Old Feb 24, 2009 | 01:31 PM
Frankieg35's Avatar
Either a 5 or 10 not sure but I know they have ones with studs on them already do a quick search u should find it..these wheels are gonna look sick with gold brembos behind them..sometimes I wish I had them but then again my next set wouldn't fit with them..
Old Feb 25, 2009 | 09:38 PM
ZeRo G35's Avatar
Anyone know where I can find 5 or 10mm spacers with the lugs? if its a 5mm do I need to put longer studs in? Thanks...
Old Feb 25, 2009 | 10:40 PM
Frankieg35's Avatar
No you don't need longer studs
Old Feb 25, 2009 | 10:51 PM
redlude97's Avatar
yes.
Old Feb 25, 2009 | 10:55 PM
ZeRo G35's Avatar
yes.
haha is that a yes that I need longer studs or a yes in agreeing with Frankie...
so realistically I can get a cheap set of 5mm spacer without longer studs and the fronts will fit fine?
Thanks!
Old Feb 25, 2009 | 11:18 PM
Frankieg35's Avatar
haha yeah what's that yes mean??
Old Feb 26, 2009 | 12:13 AM
redlude97's Avatar
yes you need longer studs
Old Feb 26, 2009 | 12:14 AM
Gdup35sedan's Avatar
ENVautoDetailing.com
+1, you need extended studs, even with 5mm spacers. The only spacer that is safe to run without extended studs is a 3mm slip spacer.
-GP-
Old Feb 26, 2009 | 10:03 AM
ZeRo G35's Avatar
Alright looks like i'll have to get spacers with studs then. What should I get with the offset, 5mm or 10mm spacer (just for the front).
Old Feb 27, 2009 | 08:16 PM
ZeRo G35's Avatar
Looks like I will be lookin got for 5mm with longer studs... 10mm is double the price =\
Old Feb 28, 2009 | 02:10 PM
ZeRo G35's Avatar
So I ordered some 5mm spacers with the longer studs... will hopefully install them and put the wheels on the spot... do I need to roll my fenders if I put the spacers on with those size rims/tires. Thanks.
Old Feb 28, 2009 | 11:51 PM
  #30
Frankieg35's Avatar
While the rims were on my car I was running tein basics and no camber kits and they were sitting just inside the fenders so with only a 5mm spacer it should be perfect..is your car lowered??
