Clearning Stock Brembo
Old Feb 22, 2009 | 10:49 AM
ZeRo G35's Avatar
19x9.5 +15 and 19x10.5 +25
Will that clear my stock brembo?
thanks!
Old Feb 22, 2009 | 10:51 AM
O HELLA OEM's Avatar
if ttranks 12 pod bbk fits on his OEM 19's im sure you'll have no problem fitting OEM brembos with the new rims your getting
Old Feb 22, 2009 | 10:55 AM
redlude97's Avatar
impossible to answer without knowing what rims in particular you are talking about
Old Feb 22, 2009 | 01:13 PM
Frankieg35's Avatar
He is talking about volks and it should fit other guys have run more aggressive offsets with brembos..if not all u would need is a very small spacer or an even better idea is to trade me your brembos for my non brembos haha!!
Old Feb 22, 2009 | 01:21 PM
Gdup35sedan's Avatar
ENVautoDetailing.com
you are very wrong. It's not just offset that determines bbk clearance, it's the pad type or disc of the wheel as well.
-GP-
Old Feb 22, 2009 | 01:25 PM
Frankieg35's Avatar
How do u determine that?? I guess just put the wheels on and then see if they fit or u need a spacer..
Old Feb 22, 2009 | 01:26 PM
when you order the wheels. or if you buy used, the original owner of the wheels should know.
-GP-
Old Feb 22, 2009 | 01:29 PM
Frankieg35's Avatar
He is talking about my wheels but I don't have brembos.. They never told me if they would fit brembos
Old Feb 22, 2009 | 01:32 PM
wait until redlude chimes in again, he's better with coupe wheel fitment. I'm more the sedan guy.
-GP-
Old Feb 22, 2009 | 01:42 PM
Frankieg35's Avatar
thanks for your help I guess there is more I need to know about offsets.. LOL
Old Feb 22, 2009 | 07:25 PM
ZeRo G35's Avatar
I heard from some they will fit fine but just want to make sure.
19x9.5 +15 and 19x10.5 +25 Volk GT-V with Nitto Neo Gen 245/35/19 and 275/35/19 tires... Need to make sure they clear the brembo...
Hopefully that will do!
Old Feb 22, 2009 | 11:28 PM
redlude97's Avatar
According to the Volk spec sheet, the 19x9.5+15 uses a B face, which will not clear OEM brembos. It will likely require between a 5-10mm spacer to make it work
http://rayswheels.co.jp/cgi-bin/cgi2...?modelName=GTV
Old Feb 23, 2009 | 12:02 AM
Frankieg35's Avatar
Thumbs down
Thanks for clearing that up.. How about the rears will they fit??thanks
Old Feb 23, 2009 | 01:44 AM
redlude97's Avatar
according to the sheet, a 10.5+25 doesn't even exist. Are you sure its not +24?
Old Feb 23, 2009 | 07:47 AM
Frankieg35's Avatar
I'm 99.9% sure it's 25..I will check after work
