Clearning Stock Brembo
Old Mar 1, 2009 | 04:50 PM
  #31
Frankieg35's Avatar
All you gotta do is adjust your camber..
Old Mar 1, 2009 | 09:40 PM
  #32
ZeRo G35's Avatar
I haven't lowered the car yet... but i'm not planning to get the rear camber kit just yet... running low on money... i do have the springs and waiting on the spacers... what i'll do is get these on prior to checking to see if the rims fit fine... i may also have to roll my fenders with the offset... i'm not an expert and was hoping others will chime in and help...
Old Mar 1, 2009 | 10:18 PM
  #33
Frankieg35's Avatar
I'm wondering if I could rig up some sort of 5mm spacer to do a test fit
Old Mar 7, 2009 | 01:41 PM
  #34
ZeRo G35's Avatar
So i got the rims and try to do a test fit... (without spacers)... couldn't see why i couldn't push it in more... i have about 10mm left from the rim that can't touch the hub... I felt around to see what was the blockage... but i couldn't feel or see anything...
is this because of the offset. I'm just a little worried now if my 5mm spacers will be enough for these to fit... please let me know anyone's thoughts... i would thing I could push the rim in but it wouldn't clear the brembo but the problem here is I can't even push it in to touch the hub arae...
thanks...
Old Mar 7, 2009 | 11:10 PM
  #35
Frankieg35's Avatar
Do u have any pics??I know the rear has little bolts between the studs so u don't put the front wheels on the back and vise versa u have to take that off when putting on the new wheels..
Old Mar 9, 2009 | 10:27 PM
  #36
ZeRo G35's Avatar
I will be going back up to Philly... letting the guys put it on for me... I guess there is a lil piece for allignment that may be in the way... from what i recall.. i didn't... will update when I put them on! Thanks!
Old Mar 10, 2009 | 09:34 AM
  #37
Frankieg35's Avatar
Your rear offset is +24 not 25 LOL might wanna fix that..yeah get then on there I wanna see pics..oh yeah I was running 35 psi in each tire..just a heads up for ya if u wanna check them cause they were just sitting for a couple months..Good Luck with getting them on..
Old Mar 10, 2009 | 11:38 AM
  #38
Frankieg35's Avatar
Where in Philly u gonna be if I'm not buisy I could stop bye..
Old Mar 10, 2009 | 01:09 PM
  #39
redlude97's Avatar
yea, did you remove the extra bolt in the front from the rotor hub? That will prevent the wheel from going in any farther
Old Mar 10, 2009 | 07:47 PM
  #40
ZeRo G35's Avatar
^^^ that's what i was thinking... will check this weekend again... could have sworn that wasn't even in the way... installing spacers anyways this weekend... and will possibly put rims on... then back to philly to put on front lip, sideskirts, and overlays... then sometime soon when my tax returns come in im gonna buy some s-techs with the rear camber kit...
Old Mar 10, 2009 | 09:03 PM
  #41
robzone's Avatar
anything will practially clear the rear brembos....Ive had the lowest of the low of disks (face of wheel) and they all have fit fine with my rears...it all depends on disk aka the face if the wheel...not the offset
Freeman186
Sep 6, 2023 10:07 AM
jilljann1
Jul 21, 2020 08:12 AM
boostelevator
Brakes
Oct 5, 2015 08:56 AM
spanky99l
Sep 7, 2015 12:46 AM
