Need help asap!!!!!!!!
Old Mar 2, 2009 | 07:52 AM
03GSDN77's Avatar
hey guys heres the deal i recently lowered my sedan around 2 inches and yesterday i put coupe 19's on it there rubbing like crazy i cant even floor the car without them rubbung i was told gettting my fenders rolled will fix this issue bc the wheels are too wide any truth to getting the fenders rolled fixing this????????
Old Mar 2, 2009 | 11:51 AM
g35freak86's Avatar
roll the fenders. it will cure the rubbing
Old Mar 2, 2009 | 12:04 PM
Tunerz_Store's Avatar
roll the fenders... or add some more negative camber.
Old Mar 2, 2009 | 12:05 PM
G35Papa's Avatar
^+1
/thread
Old Mar 2, 2009 | 12:17 PM
Wannabe6MT's Avatar
-MN G Crew-
Roll them fenders
Old Mar 2, 2009 | 12:19 PM
G35Papa's Avatar
I guess you can buy smaller tires....run more negative camber (may require an aftermarket camber kit + installation).
Rolling the fenders is probably the best choice of those
Old Mar 2, 2009 | 12:38 PM
G SEDAN's Avatar
what tire size are you running on it? I do believe that is the main culprit mixed with the fact you need to roll your fenders.
I assume you talking about flooring your car and rubbing that it is rubbing in the rear right? The rear fenders are not rolled while the front ones are rolled from the factory. Try to see if you still rub with the rear fenders rolled.
and with a 2 inch drop.....I'm pretty sure you're already running negative camber.....I wouldnt mess with it anymore unless you like the look and you have a more aggressive setup than oem 19s.
Old Mar 2, 2009 | 01:41 PM
ttrank's Avatar
Grocery getter
Roll the rear fenders or go with a ~225 on the rear.
Old Mar 2, 2009 | 07:21 PM
a 225, no way, a 235 would be more like it. 225 will look like ***.
Old Mar 2, 2009 | 10:32 PM
03GSDN77's Avatar
im running 275 in the rear the car is dropped with tein htechs and 350z struts all around im hoping the fender roll will do the trick
andrewvk
Engine - Complete Motors
32
Apr 7, 2016 01:39 PM
_evilMonkey_
2nd Gen (V36) Sedan
Nov 22, 2015 06:21 PM
esy
Sep 1, 2015 09:10 PM
Ray Feta
Aug 20, 2015 08:46 PM
poker_lamina
Aug 14, 2015 12:57 AM
