05 G Coupe Suspension Problems
I have read from the forums here that the 05 coupe suspension is the worst suspension in the G line up? Why is that?
What is the real upgrade of the G SPORT TUNES suspension?--http://www.automotivehelper.com/topic456778.htm
*06 sway bars are way better than the 05.
*05 endlinks are way beefier than 03-04 and are used when upgrading sway bars.
*05 received the upgrade 19 inch tires without an upgrade in suspension sway bars..Is this the reason?
*I have read this in previous threads...Im just wondering why people said 05 had terrible suspensions was it just what i stated? or is there more?
See the sway bar and spring stickies in this forum.
The front coupe sway bar is the same in all years. Starting in 2005, the coupe rear sway bar (only) was made stiffer. It's the same sway bar in 05 and 06.
The real difference in the 05 and up suspension comes down to stiffer rear springs and stiffer shocks all around. This is a big improvement in the handling of the coupe.
And remember, though Infiniti went to 19" wheels, the widths and diameters of the wheel/tire combo did not change, so that's more or less a wash as the unsprung weight didn't change much either.
https://directtuning.com/store/pc-72...dan-03-07.aspx
So why does adding sway bars to the coupe in 05 make a bigger difference than an 06?
laksjd84
Steering & Suspension
16
Jul 12, 2017 12:22 AM
