Ride height
Old Mar 19, 2009 | 08:18 PM
G1ZZR's Avatar
Ride height
Hey all,
Quick question, on a 03 sedan with sport tuned suspension does the ride height differ from the non-sport models? I know the spring rates are stiffer and the shocks are red just to prove I did some searching before I posted! Thanks in advance.
Old Mar 20, 2009 | 02:12 PM
G1ZZR's Avatar
Anyone? I have a blown shock and contemplating on replacing with oem or to go with a new setup preferably coilovers.
Old Mar 31, 2009 | 02:14 PM
OKStateG35's Avatar
I would also like to know the answer to this question.
Old Mar 31, 2009 | 04:46 PM
Skaterbasist's Avatar
Retired SuperMod
I highly doubt they differ at all. The only difference, as you pointed out should be the spring rates. Maybe some sedan guru's come chime in.
Old Mar 31, 2009 | 05:50 PM
OKStateG35's Avatar
I was interested because I have an '05X and would like to do a very mild (approx. 1") drop. If my car was RWD I would just put in a Z/Coupe setup and be done with it. The fact that it's an X makes it a little more complicated because it is heavier and will have more of a drop with the same springs.
I also prefer a somewhat stiff ride so that's why I was asking about the sport springs. After doing some more searching though I actually found that the stock X springs have a higher rate than the sedan sports so it may actually make the ride less stiff. Anyway, I didn't figure the sports would give any drop over the non-sports, but just thought I'd ask.
Old Apr 1, 2009 | 11:00 AM
Gsedan35's Avatar
Originally Posted by G1ZZR
Hey all,
Same height.
Old Apr 1, 2009 | 11:03 AM
Gsedan35's Avatar
In the factory service manuel for the G35X, what does it show for ride height on the alignment spec page?
IIRC, I once read that the AWD sedan rides .5" higher then the RWD sedan, seeing what the FSM show's would be best however.
KruZZe
Feb 27, 2023 05:04 PM
sales@czp
Suspension-Vendor
26
Nov 6, 2017 03:04 PM
prinny
Nov 22, 2015 11:07 PM
Fox843
Nov 7, 2015 05:43 PM
gprabhu
19 Inch
Oct 2, 2015 05:55 PM
