new rotors feel warped when hot
Old Mar 26, 2009 | 12:25 PM
UrangeAve's Avatar
Originally Posted by IMAFUKINRIDER
nice customer service ..
good to see it still exists ...
I agree! Good customer service is very hard to find. Ive had bad luck the last few weeks . Thanks David.
Old Mar 26, 2009 | 02:24 PM
Q45tech's Avatar
A perfect rotor can appear to have runout when mounted on a marginal hub. The ratio of hub radius to rotor radius creates a multiplier effect.
So the hub MUST measure LESS THAN 0.001" otherwise a perfect rotor will show out of spec.
Old Mar 26, 2009 | 05:23 PM
Tollboothwilley's Avatar
The OC Autosports are made of high quality materials. They work great. I've had them on my car for a while. It sounds like you might have done something wrong in the bed-in process. That, or the rotors had a problem.
OC Autosports will warranty the rotors as well. Call them up and they'll work with you I'm sure.
Old Mar 26, 2009 | 08:01 PM
dofu's Avatar
20 Year Member
+1. One faulty part here and there is not a big deal... it will happen to anybody. But getting the part replaced can be pretty impossible without the good customer service...
Old Mar 28, 2009 | 07:20 PM
pczavala's Avatar
Got my rotors from OCAutosport on friday, got them installed and loving them, no issues at all and install was easy.
+1 on excellent customer service, David is a great guy.
Old Mar 30, 2009 | 01:20 PM
Q45tech's Avatar
"A lot of aftermarker rotor companies use cheaper steels to increase their margins"
I certain hope they don't use steels as rotors are made from various quality grades of GREY CAST IRON.
The Foundry location where the blanks are poured is very important.
If you care about rotors you should understand this:
http://www.sae.org/events/bce/tutorial-ihm.pdf
Old Mar 31, 2009 | 12:18 AM
UrangeAve's Avatar
Same here. My car actually stops now
G35Rican
Jul 31, 2024 01:37 AM
RyanRebel54
Drivetrain
Oct 11, 2017 11:45 PM
NJ6MT
Sep 10, 2015 08:40 AM
3000vr4tt
Sep 7, 2015 12:48 AM
