SS brake lines worth it?
Old Mar 23, 2009 | 01:29 AM
TurTLe*'s Avatar
Simple question i guess. I know its worth it for people who track and auto-x.
But in terms of daily driving/ once in a while spirited drive situations. I've always consider getting them done but when it came around time for it i just never did it. As far as the work goes its pretty easy and i've done one line before. Overall i'm happy with the stock setup and now looking to run hawks HPS pads, so the question is would the SS have an acutal benefit for me?
Old Mar 23, 2009 | 09:46 PM
ollie23's Avatar
Since you helped me out, here is my reponse :
I have all 4 line replaced to stoptech steel lines. IN my opinion, there is no real difference that I can feel on a daily basis. I'm sure it's going to help in the long run. But on the daily drive, there is not much difference.
PS: I also just out Hawks HPS pads. Do they grip a lot on your ride?
Ollie
Old Mar 23, 2009 | 09:59 PM
eljoker's Avatar
its mostly for sense of mind really. Like you said track and auto x is diffrent but DD, its like running BBK, which has been proven not do do much in DD. Id still go for it just becuase SS brake lines last longer than stock.
Old Mar 23, 2009 | 10:02 PM
Triple8Sol's Avatar
SS lines are to reduce brake fade from repeated hard braking, which boils the fluid and causes stock rubber lines to expand.
For daily driving? Really no difference.
Old Mar 23, 2009 | 10:32 PM
TurTLe*'s Avatar
I've never seen a broken brake line that wasn't cut or due to a retard installing the strut wrong.
in most normal cases brakes lines just dont wear out to me as much. They are made pretty much to last the line of the car hence why i never replaced it or found a purpose to replace it.
I haven't tested the HPS pads yet, I ask about the lines because there are package deals out there.
Old Mar 23, 2009 | 10:52 PM
eljoker's Avatar
idk most the cars ive owned had to had them replace once i hit 100k becuase they either busted or were leaking but then again those were chevys
Old Mar 24, 2009 | 12:49 AM
TurTLe*'s Avatar
this is my 4th car, the past 3 i've taken it to 100k+, i've dont a lot of work on people's cars as well and hardly ever hear that they replaced a line or saw anything leaking.
jsimonk
Dec 22, 2023 03:49 PM
Machine Head
19 Inch
Mar 16, 2016 08:55 PM
bryanr
Drivetrain
Sep 30, 2015 06:31 AM
Jnm07
Sep 5, 2015 01:16 AM
linedr89
Aug 17, 2015 05:11 PM
