Inner tie rod
Inner tie rod
I believe I have determined that my highway-speed shake is from a defective left inner tie rod.
The boot is torn, and much of the grease has leaked out.
The service manual only shows the replacement procedure on a bench with the entire rack removed. Is this really necessary? I can't seem to find the exact spot where the inner tie-rod can be separated from the rack in the service manual; only the reassembly procedure.
FS[NorEast]: New OEM G35x Compression Rods - Save!!
The Fixer
Steering & Suspension
Nov 1, 2015 03:26 PM
frankywashere
Sep 2, 2015 01:22 AM
