bleeding brembos
bleeding brembos
does anyone know if it matters whether you bleed the inner or outer bleed valve first? the service manual makes no reference to the two valves on the brembo calipers
pics for reference:
pics for reference:
it just refers you to BR-9 (or 10, can't remember), which is just a generic how to
BR-10, doesnt say, I dont think it really matters since it comes from the same source. I've done it many times...
Bleed air in the following order. Right rear brake → Left
front brake → Left rear brake → Right front brake
1. Connect a transparent vinyl tube to air bleeder.
2. Fully depress brake pedal several times.
3. With brake pedal depressed, open air bleeder to release air.
4. Close air bleeder.
5. Release brake pedal slowly.
6. Repeat steps 2, through 5, until clear brake fluid comes out
of air bleeder
of air bleeder
of air bleeder
of air bleeder
i guess i'll just do the inners and then the outers
either that or maybe i'll call my dealership and see what the techs do there
Incorrect, do it in the order that G35 Mass listed doing inner first then the outer bleeder.
well right, i meant it they said it doesn't matter whether you do the inner or outer first, but i'm doing the inners first
Right Rear
Left Front
Left Rear
Right Front
i know that matters
Right Rear
Left Front
Left Rear
Right Front
i know that matters
tadmcmichael
Brakes
Oct 18, 2015 01:47 PM
BradMD_96
Oct 6, 2015 09:31 AM
