Designing a Fade Stop Brake Cooler for G35 - need a caliper
Old Mar 25, 2009 | 03:33 PM
jrdemers's Avatar
Brakes Designing a Fade Stop Brake Cooler for G35 - need a caliper
Hi all,
I am designing a Fade Stop Brake Cooler (http://www.fourproducts.com) for the G35 Coupe and the 350Z (standard single piston caliper - you Brembo guys probably don't need coolers yet). I am to the point that I need to test fit initial designs and am looking to buy a front caliper and bracket for the '03 - '04 G35/350Z. I am also designing for the '05 and later, but that will come next. If anyone has a used one for sale, even if it has a damaged piston I would be interested in buying it from you instead of Kragen.
Let me know!
Thanks,
Joe
Old Mar 26, 2009 | 03:32 PM
jrdemers's Avatar
I just posted the caliper request to the Wanted section. I am leaving this thread here though so that I can get any comments about brake coolers. The designs for the G35/350Z are extremely cool (no-pun intended) and I will post pictures when the prototypes are manufactured.
Old Mar 26, 2009 | 04:26 PM
redlude97's Avatar
this seems kind of pointless to design one for that braking system. Almost everyone who tracks their car seriously has at least the brembo calipers or another BBK system. These brakes also only came on automatic transmission 03-04 RWD G35's and 03-05 AWD sedans.
Old Mar 26, 2009 | 04:30 PM
jrdemers's Avatar
I would love to hear feedback on this point!
The brake coolers are significantly cheaper than a caliper upgrade, but maybe I should concentrate on designs for the Brembos. The biggest sales of coolers so far have been with the classic Porsche 911s because they can not upgrade the brakes for their racing class...
SDGenius's Avatar
cool-ish idea
Old Mar 26, 2009 | 05:38 PM
jrdemers's Avatar
I personally own an '04 coupe. My research has indicated that the '03 and '04 coupe share a caliper with the '03 and '04 350Z - is this correct? After those years it becomes more confusing, but I would like to resolve it and make a cooler for the most desired and common caliper.
This what I have found on the Forum - does anyone have part numbers they can point me towards?
'03 and '04 Sedan, '04 and '05 Sedan X
Front: 11.7-inch X 0.9-inch power-assisted vented disc - 1 piston
Rear: 11.5-inch X 0.6-inch power-assisted vented disc - 1 piston
'05+ Sedan and Coupe, '06 Sedan X
Front: 12.6-inch X 1.1-inch power-assisted vented disc - 2 pistons
Rear: 12.1-inch X .63-inch power-assisted vented disc - 1 piston
'03 and '04 Non-Brembo Coupes
Front: 11.65-inch x 0.94-inch power-assisted vented disc - 1 piston
Rear: 11.5-inch x 0.63-inch power-assisted vented disc - 1 piston
'03 and '04 Coupe Brembos
BremboŽ brakes
Front: 12.76-inch x 1.18-inch power-assisted - 4 pistons
Rear: 12.68-inch x 0.87-inch - 2 pistons
Thanks,
Joe
silencedeyes
Brakes
Nov 26, 2015 05:36 PM
netcbc
Exterior - Body Parts CDN
Aug 21, 2015 09:50 AM
kinetek
Aug 3, 2015 04:25 PM
laksjd84
Jul 24, 2015 05:12 PM
mushu
Jul 15, 2015 03:55 PM
