Help me!
Old Mar 26, 2009 | 12:52 AM
biggz786786's Avatar
Exclamation Help me!
hey all, i have a really big annoying problem
something is wrong with my suspension
whenever i reverse, i get the loud clicking noise, but not just one click, its like a bunch of clicks, some loud some not so loud, all at the same time, then when i put in drive, i get that clicking noise for like a second, but once i get the car going then it stops
before it wouldn't happen a lot, now it happens every single friggen time!
i took it to infiniti, at first they found my rear axle bolt worn out, they replaced it under warranty, the problem was still there but not that loud when i took it out of the dealership, then they thought it was my e-brake, they re-adjusted it but nothing....they wanted to believe that it wasn't my suspension, but seems like it is
im lowered on graddy type-s coilovers and spl pro rear camber adjustable arms......im probably 85% positive that it is my coilovers, when ever it happens, which is all the time, i get out of the car when i park(in reverse) i hear like one click, so that must be my coilovers, then i sort of put the wheel, like a little jerk, and i hear it, so that re-assures me that it is my coilovers......im hoping it is not my control arm or end links
it pretty much started happening when it got cold, im thinking maybe the cold weather is causing this, but i have not herd any of my friends have this kind of problem with there aftermarket suspension
i guess its not really "clicks" but its somewhere between clicks and clanks, hard to say, does any body know if i have to lubricate anything? or replace my bushings? or my pillow ball????
if anyone can help, i would greatly appreciate it!
thanks a lot!
Old Mar 26, 2009 | 05:37 AM
EL-EE-ES's Avatar
is everything bolted up tight? when you drive the car foward do you feel vibration or extra road noise? you said that when you pull on the wheel you hear it, bad bear maybe? https://g35driver.com/forums/brakes-...ring-pics.html
Old Mar 26, 2009 | 06:03 AM
^hmm im not sure that is the case, the noise is coming from my rear suspension only
i don't have to pull the wheel to hear it either, i just simply put it in reverse, don't need to steer, and it happens, also, the noise started to happen sometime after i put my stock wheels back on for winter....i still am on stock wheels untill next month
Old Mar 27, 2009 | 01:52 AM
nobody?
if it is bad bearings, why so soon?
i only have 60,000 km
i don't think it is because of my aftermarket suspension or my aftermarket brake pads, so does anybody know if infiniti will cover it under warranty? if it is bad bearings?
thanks
Old Mar 28, 2009 | 03:59 PM
bump
does anybody know if the dealership will fix it under warranty if it is bad bearings?
thanks
