JIC Magic Coilover question
I just installed some Flt-tar and discovered they were pretty stiff. I did some research and found out i can buy some helper springs to help the stiffness. i was wondering if anyone else has this set up.
http://www.evasivemotorsports.com/Me..._HELPER_SPRING
i was also wondering whats the difference between
I.D. - Height (mm) 62mm - 50mm
Spring Rate 1.6kg/mm
I.D. - Height (mm) 62mm - 80mm
Spring Rate 2.1kg/mm
Which one would be better to improve ride quality?
ONE LAST THING.. adjustable endlinks should fix the problem to the rattle/creeking noise in the rear?
THANKS IN ADVANCE!!
THANKS IN ADVANCE!!
netcbc
Steering & Suspension CDN
Jul 24, 2015 11:25 AM
