04 Standard Front Brake Install - Wrench Sizes?
Old Apr 7, 2009 | 03:30 PM
Dwight Schrute's Avatar
I'll be installing new factory rotors and pads on the wife's 04 sedan Saturday morning. This is the first foreign car I've done real work on, and I'm just trying to make sure I have all the right size metric wrenches and sockets I'll need before the car is up on the jack stands.
Does anyone know what sizes I'll need for rotor removal and caliper disassembly? Thanks.
Old Apr 7, 2009 | 03:35 PM
Jeff92se's Avatar
Red Card Crew
Any standard set of metrics 8,10,12,14,17 + should contain what you need. Even a 3/8" drive is probably large enough to handle. I'd recommend a breaker bar for the caliper bolts though.
BTW. If I remember, the lug is 21 or 22 mm. I'd recommend a 1/2" drive for that.
Old Apr 7, 2009 | 03:50 PM
ttrank's Avatar
Grocery getter
Why was this in the sedan section?
Old Apr 7, 2009 | 03:55 PM
Jeff92se's Avatar
Red Card Crew
I gave him a break seeing as it's his 1st post.
To the OP, consider doing brake fluid flush and checking the rear parking brake drum adjustment. You'll be back there anyway when removing the rear rotors anyway
Tolboothwilley™
Exterior-Vendor
Jul 28, 2016 12:42 AM
marsman328
Northern California
Aug 11, 2015 07:29 PM
wojowojo16
Jul 27, 2015 09:57 AM
realtalk21
Jul 20, 2015 09:07 AM
