help pls, problem with rear suspension
hi, i have an 06 g35 coupe
im lowered on greddy type-s coilovers and spl pro rear camber arms
just a few weeks ago, i have hearing squeaking noises, LOUD squeaking noises, coming from the rear suspension, it squeaks from the slightest bumps or uneven roads, and it squeaks really really loud on speed bumps
does anyone know whats wrong?, does it need some sort of lubrication? or could it be something far worse? have my rear suspension crapped out or something? i would really like to know asap please
thank you!
thank you!
i kinda have the same problem. but the noisy my car makes is not too loud, i can hear it tho. As far as i can tell, i think its a bumping noise n i have it checked by a auto shop. they told me they tied things up a lil bit, but still didnt solve the problem
ENVautoDetailing.com
put a piece of soft foam cut to the shape of the top mount on the rear shock in between the mount and the body. My car does the same thing, it's metal to metal up there and if dirt gets in then it squeaks. I just took apart my rear suspension today and cleaned everything off and adjusted it.
-GP-
-GP-
really? dirt can cause it to squeak? i even get it a lot while driving now, on any road because no road is smooth!
i even have rear clicking noises, infiniti just adjusted me e-brake and rear axle and there is absolutely nothing else they can do because of the aftermarket suspension and brake pads
so now i gotta take it to an aftermarket shop to get it all sorted out
rezendvous420
May 31, 2020 01:26 PM
