GTSPEC/Circuit Sports under bars & alignment
Old Apr 13, 2009 | 09:28 AM
IVRY PRL's Avatar
So I have a set of these on their way to me, namely the front and rear under bars, the one that ties the two front LCA's together and the one that beefs up the rear subframe.
However, I just got coilovers and an SPC rear camber kit put on. From what I've read on the forum, these will fit with the rear camber kit, however, will their install mess up my alignment? I'm wondering, because the places they mount seem to be places that have eccentric bolts for alignment. By undoing the nuts to install these bars, do the eccentric bolts not become loose and change my settings?
The reason I'm asking is, I want to get my car aligned, but I want to know whether I can do it now, before I get these bars put on, or if I have to wait for them to come in, put them on, and then get the car aligned. I obviously don't want to pay for an alignment twice in two weeks, so this is why it's so important to know.
Old Apr 13, 2009 | 09:42 AM
gary c's Avatar
Simple solution, have those under bars installed then get the alignment. On the rear bar the holes may need to be elongated to match the toe bolts. Sounds like a very cool set up IP, post some pic upon completion....
Gary
Old Apr 13, 2009 | 10:42 AM
IVRY PRL's Avatar
Mmm.. okay, sounds good. The reason why I was asking, is I wanted to be certain, because I don't like driving around for very long without a proper alignment, so if I'm going to wait, I'd like to be certain that I have to wait.
Old Apr 13, 2009 | 12:03 PM
redlude97's Avatar
it will mess up your alignment. You will also need longer eccentric bolts from SPC to fit with the gtspec bars, the ones that come with the kit are not long enough
xx7sephiroth7xx
Brakes
May 3, 2023 07:07 PM
seagrasser
May 3, 2022 09:43 AM
Jyounya
Sep 12, 2015 02:29 PM
spanky99l
Sep 7, 2015 12:46 AM
migurus
Sep 5, 2015 09:39 PM
