Yay!! New comression rods!!
Ok, so I got my new compression rods in today from everythingg35.com, $297 shipped, not bad. Anywas Im wondering how hard installing them myself would be. I cant seem to find a manual for the G35. If anyone can point me in the right direction, I would appreciate it. THANKS!
Doesn't seem to hard, i'll be doing mine next weekend.
https://g35driver.com/forums/faq-diy...df-format.html
Go there to DL the service manual and look into fsu.pdf for the front suspension and rsu for the rear.
do you order parts from the states?
also, btw, are these compression rod front suspension component? or does the rear have compression rod as well? its not same as the endlink of sway bar, right?
recently i hear this popping noise whenever i come to a complete stop or whenever i start moving the car (i don't do hard launch). and when i drive, i can hear some clunking like you're dragging a metal piece or scrapping something.
i'm trying to think if its the (1) endlinks to sway, (2) compression rod (if they exist at the rear), or (3) axle needs to be re-torque or replaced. (4) or totally something else
on compression rods i found this
http://www.mynismo.com/products/Default.asp?id=5348#
NISMO Hard Rubber Bushing Kit - 350Z/G35
NISMO Hard Rubber Bushing Kit For the 350Z and G35. Includes 22 Higher Durometer Bushings In The Kit. Also Can Be Sold Seperately.
Kit includes 22 increased durometer bushings:
-Front upper A arm bushing (4 needed per car)
-Front lower transverse link bushing (2 needed per car)
-Rear upper A arm bushing (4 needed per car)
-Rear radius rod (toe link) at hub bushing (2 needed per car)
-Rear radius rod (toe link) at body bushing (2 needed per car)
-Rear lower link (camber link) at hub bushing (2 needed per car)
-Rear lower link (camber link) at body bushing (2 needed per car)
-Rear lower control arm (spring arm) bushing (2 needed per car)
-Rear upper shock absorber bushing (2 needed per car)
according to the other thread . the transverse link bushings are compression rods bushings.
if i havent read it worng thats what your looking for ..
and you can go to the thread and ask your own questions ..
hope it helps guys ..
The STRUT ROD, aka COMPRESSION ROD. If you go under everythingg35.com OEM parts listing, type in strut rod.
LINK- http://www.trademotion.com/partlocat...e=14&model=G35
Also there are only strut rods in the front.
FS[NorEast]: New OEM G35x Compression Rods - Save!!
The Fixer
Steering & Suspension
Nov 1, 2015 03:26 PM
