GT Spec Front Tie Brace Question?
Old Apr 25, 2009 | 11:41 PM
kparlett's Avatar
Exclamation GT Spec Front Tie Brace Question?
Im in the process of installing my front lower tie brace and am wondering if when i take the bolt out is the lower a arm going to fall due to the weight of the shock, and whether i need to put a jack under the arm to keep it from falling? Ive done tons of searches and have come up empty handed. Please help asap. Thanks
Old Apr 25, 2009 | 11:42 PM
kparlett's Avatar
a link to a DIY would be great if any one can find one, i didnt have much luck
Old Apr 26, 2009 | 09:22 AM
kparlett's Avatar
Anybody????
Old Apr 26, 2009 | 09:29 AM
Vrod-Mike's Avatar
I should be installing mine tonight. I'll let you know once i'm done.
Old Apr 26, 2009 | 09:48 AM
kparlett's Avatar
thanks, i just hope someone answers sooner then that because my car is sitting on the lift right now.
Old Apr 26, 2009 | 09:56 AM
g35man04's Avatar
CLUB MODERATOR
I cant remember exactly when I did mine...but I dont remember there being an issue.
Old Apr 26, 2009 | 09:57 AM
g35man04's Avatar
CLUB MODERATOR
I am ordering them all again though at the end of the week.
Old Apr 26, 2009 | 10:06 AM
kparlett's Avatar
the problem is once i removed the bolt the a arm dropped, i had a block of wood under it to hold it up but it fell about an inch and now the holes dont line up to install the bolt. The car isnt jacked up, just on a drive up lift.
Old Apr 26, 2009 | 10:36 AM
Vrod-Mike's Avatar
Can't you just get a jack under it? If you can't get a jack under it use a pry bar to lift it back up.
Old Apr 26, 2009 | 11:49 AM
g35man04's Avatar
CLUB MODERATOR
yeah a pry bar or jack on the bottom-side to jack it up to line it back up.
Old Apr 26, 2009 | 01:28 PM
kparlett's Avatar
well it was a pain and i used some serious rigging to get it to work but i got it back in place. I didnt install the bar though because looking at the design of the car there is no way that Tie Brace does anything at all. The lower control arms are already mounted to a solid piece of steel that connects to each other. Adding a piece of softer aluminum to the equation isnt making anything stronger. SO does anyone wanna buy a New in box front tie brace?
Old Apr 27, 2009 | 05:06 AM
Triple8Sol's Avatar
Jack up your car so the wheels are off the ground. You should be able to make it work that way.
silencedeyes
Brakes
Nov 26, 2015 05:36 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
jimNC
Jul 25, 2015 05:47 AM
Soumilg
Jul 18, 2015 12:33 PM
