Need some info on Drop
Old Apr 29, 2009 | 02:43 PM
CJG35Coupe's Avatar
Hello,
New to the G35's and to this community as you can see. I just got some wheels 20x9 15mm and 20x11 20mm and wanted to dump the hell out of the car but do not have airbag or coil over money. What springs would give me the lowest drop? Looking for the no gap look or even tucking a little bit of the tire. Thank you guys for helping and looking forward to learning from all you guru's out there. Some serious cars in here
CJ
PS
I'm a Newbi so please bare with me on how this forum board thing works
Old Apr 29, 2009 | 05:19 PM
zer0one's Avatar
I just bought the Eibach Sportline Springs, and the car is in the shop as I type.
The sportlines are a 1.7" Front Drop and a 1.4 Rear Drop. Worth checking out. Although I have smaller wheels than you. 18x8 245/40, and 18x9 275/40. Im expecting to bring the fender right down to the wheel.
Its cost me $250 (w/shipping on ebay) for the springs, and another $200 for a shop to put them on (which is cheap, most places wanted $350) . Now Im being told I need to do something else to the rear in order to Align it properly. Ill find out what when I go to pick it up. The alignment is going to cost more too I assume.
Old Apr 29, 2009 | 07:32 PM
eurodre's Avatar
the problem here is no money for coilovers or for bags. I understand what it's like not to have money to do what you want but despite that if you want to achieving dumping the hell out of the car it WILL cost you a good amount of money. I suggest save up because springs won't get you the kind of lowered ride height like coilovers can
Old Apr 30, 2009 | 10:27 AM
zer0one's Avatar
I agree with eurodre. I like my drop but to slam it you would want better equipment. I wouldn't recommend more than a 1.5 inch drop with just springs. The ride will get horrible and Im already having scraping issues on bad roads.
Not to mention the rear camber equipment I have to buy now to align the tires. 4 - 6 hundred $. Its expensive no matter what rout you go. Best to do it right.
Of course, when I was 17 we would just cut the stock springs with a circular saw. That was free. Man I messed up some cars when I was young.
Old Apr 30, 2009 | 01:58 PM
CJG35Coupe's Avatar
Thanks for your guys help, Can you post pics when your car is done so I can see your drop?
Thanks again guys
Old Apr 30, 2009 | 02:07 PM
eurodre's Avatar
look in my garage for a pic of mine as well
Old Apr 30, 2009 | 02:15 PM
elayman's Avatar
go with z tein s-techs. they'll drop you just over an inch which should close the gap completely
Old Apr 30, 2009 | 02:36 PM
zer0one's Avatar
Just uploaded some pics to my Garage
https://g35driver.com/forums/garage....&vehicleid=708
Old May 1, 2009 | 05:49 PM
TXaaron3232's Avatar
Would these require a camber kit, or are they not quite low enough to really need it?
Old May 1, 2009 | 11:03 PM
elayman's Avatar
I would suggest getting rear camber kit. that's what I have, but you can run without one, but your tires will suffer.. in the end $150 for the camber kit + $100-150 for the install + $150 for alignment (which you would do anyways) seems worth it with 150-250$ a piece tires.
DRG35R
Jan 31, 2016 07:14 AM
The Fixer
Steering & Suspension
Nov 1, 2015 03:26 PM
Rose M
Oct 12, 2015 10:00 AM
TurTLe*
Sep 29, 2015 01:43 PM
