Tpms light
Old May 11, 2009 | 07:58 PM
mhaynard21's Avatar
Tpms light
hi all! couple of weeks ago i traded my oem wheels for 19' maya rims then after 2 weeks while im driving suddenly my tpms went on then checked all my tires if it need to be servive but there all alright.
Old May 11, 2009 | 09:10 PM
Vrod-Mike's Avatar
Did you put new TPMS in the tires and have the ECU reset to accept them? If not you need to go to a dealer or someone else that has the equipment to reset the system.
Old May 11, 2009 | 09:18 PM
erklep's Avatar
yes, the bcm needs to learn the new data from the new sensors. they have a different data code that the bcm is not finding
Old May 11, 2009 | 09:22 PM
Dubi2087's Avatar
Make sure the air pressure is above 32 if not it will go off also go to discount tire and they will reset it for you. They may or may not charge you, if you were in Orlando I would do it for free but if they charge you it won't be anywhere near what the stealership charges.
Hopefully whoever installed them didn't break one..
Old May 11, 2009 | 10:42 PM
mhaynard21's Avatar
new tpms? is the tpms is connected to the wheels or just somewhere in the car. can i just discoonect my batt to reset my ecu?
and thank you for the info
Old May 11, 2009 | 10:52 PM
Vrod-Mike's Avatar
Each wheel has a sensor in it, so unless you removed them from your old wheels you need new ones for these wheels. Then the sensors need to be setup with the ecu which requires a scan tool.
Old May 12, 2009 | 12:22 PM
mhaynard21's Avatar
[QUOTE=Vrod-Mike;4209462]Each wheel has a sensor in it, so unless you removed them from your old wheels you need new ones for these wheels. Then the sensors need to be setup with the ecu which requires a scan tool.[/QUOmy
my new wheels were used to be on 03 g35 coupe so im assuming theres a sensor on it, so i have to go to the dealer to have them reset my ecu?
Old May 12, 2009 | 01:41 PM
erklep's Avatar
the new sensors have to be learned to the bcm
Machine Head
19 Inch
Mar 16, 2016 08:55 PM
Depravity
19 Inch
55
Oct 16, 2015 01:36 PM
Frankieg35
Sep 9, 2015 12:17 AM
PZ06G
Aug 27, 2015 06:11 PM
TheKnite
Aug 14, 2015 07:59 PM
