1pc vs 2pc rotor?
Old May 16, 2009 | 12:34 AM
syshs's Avatar
1pc vs 2pc rotor?
What's the difference between 1pc rotor and 2pc rotor?
Is it to only do with the weight?
What are the pros and cons of each?
Thanks.
Old May 16, 2009 | 01:44 AM
syshs's Avatar
I found this on google for 2pc rotor...
Advantages:
* Lighter rotor (12-16% weight reduction varied with the size and design) than original one-piece rotor – meaning lower spinning weight.
* Cooler disc - due to higher heat dissipation rate of aluminum hat as compared to cast iron
* True full floating design (unlike others out in the marketplace) allows the disc to expand and contract freely without stressing the hat. This helps prevent the disc from warping or cracking.
* Allows consumers to replace only the rotor ring, while reusiing the hat. Although the initial cost of two-piece rotors is higher than one-piece rotors, the lifetime operating cost could be lower.
Any other pointers anybody?
Old May 16, 2009 | 01:28 PM
terrycs's Avatar
1 piece rotor is also usually cheaper.
If this is for daily driving and you are not that agressive with the brakes, either will work. IMO, I'd go with 1 piece to save $$ assuming you are staying with stock calipers.
However if you are uprading calipers, then you most likely have to go with 2 piece.
Old May 16, 2009 | 05:58 PM
terrasmak's Avatar
G Sedan
Unless you track your car regularly don't bother with 2 piece rotors.
Old May 16, 2009 | 09:37 PM
syshs's Avatar
^ Yeah, so I hear. I guess I will go w the 1pc.
Marlin84
Apr 1, 2020 12:52 PM
Picture Share
Feb 4, 2018 12:41 PM
nanobotking
Oct 8, 2015 08:40 AM
dcsbh1
Oct 1, 2015 03:15 PM
alinero718
Sep 27, 2015 09:35 PM
