brembo break swap
Old May 23, 2009 | 12:26 AM
nwillia's Avatar
brembo break swap
ok so i'm sure this has been covered but I need help bad. I purchased new a 2005 g35 and have always wanted the factory brembos on my car. after a long search I have found some. yesterday I swaped out my factory set up with the brembos new pads and steel lines and EBC rotors dimpled and slotted. I also changed the fluid with cool blue. my problem is the breaks seem to always be engaged. The noise is constant like there constantly being applied, and there is a large amount of break dust getting all over my brand new Iforged wheels and its driving me nuts!!! i heard that some people have changed the master c. I am thinking this may have something to do with my problem, any help would be awesome!!!
Old May 23, 2009 | 12:30 AM
GLuXuRy's Avatar
is it all corners that are binding or just one ? .. i cant believe its the master cylinder if your brakes were not doing this before
Old May 23, 2009 | 12:52 AM
vincentl's Avatar
make sure your bolts are are properly torqued. See Service manual.
Old May 26, 2009 | 11:33 AM
prj3ctm4yh3m's Avatar
seals
Old May 26, 2009 | 12:50 PM
nwillia's Avatar
you think? seals really?? what makes you think that? I am not wanting to get into all that but if I have to that would suck!!
Old May 26, 2009 | 01:04 PM
when they get dirty/old/hot they can cause the pistons to stick. REAL race calipers a la Wilwoods do not have dust seals- to consistently handle the higher temperatures.
Old May 26, 2009 | 01:42 PM
vincentl's Avatar
During the break-in period for my hawks, the brakes seemed like they were rubbing constantly and there was a ton of dust. Wait a bit.
Old May 26, 2009 | 01:46 PM
G35Papa's Avatar
Is it a loud grinding/rubbing? Did you do the install yourself? Make sure you re-used the washers on the two bolts that hold the caliper to the hub.
I remember reading up somewhere that the rears on the OEM Brembos had a sticking problem. A good clean resolved that issue.
Old May 26, 2009 | 04:32 PM
05Scoobyroo's Avatar
+2 ......Just changed my brakes yesterday, and its normal to hear the sound of the pads touching the rotor while you drive, but its really only audible at lower speeds.
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
andrewvk
Engine - Complete Motors
32
Apr 7, 2016 01:39 PM
prinny
Nov 22, 2015 11:07 PM
