OEM Spring and Camber Arm swap?
Old May 23, 2009 | 10:35 AM
BuckeyeInMI's Avatar
I've read tons of threads about swapping OEM springs to get a nice, cheap drop (Coupe/Z combo, Z all around, etc.). Many of these require new shocks/struts so you don't bounce or wear out the original OEMs. Many also require a camber kit if you don't want either the negative camber look or prematurely worn out tires.
So, here's my question. What's the difference between the camber arms/upper links from the various models (Z, Coupe, Sedan, X)? If I'm dropping a Sedan with Coupe springs, could I also swap out the upper links and keep my suspension aligned (i.e., no negative camber)?
I've checked a few places for OEM parts, and the Z, Coupe, and Sedan upper links are the same price, but I don't know if they're the same part. The X part is more money.
Old May 26, 2009 | 08:27 PM
TurTLe*'s Avatar
i see where you are coming from but i think its pending the position of the shock. its most likely the same arms but the obviously you can position them a lot of different ways.
camber kits allow for positive and negative adjustments but almost all cases of lowering requires you to add more positive camber to bring it back to stock.
if you take the arms with the springs your just going to be doing more work because the arms are the same. least thats how i view things.
jsimonk
Dec 22, 2023 03:49 PM
Frostbite91
Aug 12, 2015 05:16 PM
teamghost
Jul 28, 2015 04:52 PM
netcbc
Steering & Suspension CDN
Jul 24, 2015 01:59 PM
