need help with strut bar clearance
Old May 29, 2009 | 06:37 PM
myroncuz's Avatar
ok, right now i have a 5/16ths spacer. im about to purchase mrev2 and kinetix v+ upper plenum. which strut bar will fit with these?
ive contacted motordyne and they said the stillen bar will fit with their mrev and the 5/16ths but not sure with the kinetix plenum.
kinetix says that their plenum is slightly bigger then stock and that it MIGHT fit with the spacer but they also said that i might have hood clearance issues and may need longer bolts..
stillen says they DONT believe their strut bar will fit with the plenum or the spacer..
then another stillen rep says it will not fit with neither the spacer or plenum...
anyone? help is greatly appreciated.. thanks
Old May 31, 2009 | 04:11 PM
PTownG's Avatar
The NRG bar should fit. There is a ton of space between the bar and the top of the plenum, enough in fact that it will rub on your hood
VatoVazq
Steering & Suspension
16
Jan 3, 2025 11:08 PM
Claudiu
V36 Brakes, Suspension, Wheels & Tires
Mar 10, 2018 11:38 AM
Picture Share
Feb 4, 2018 12:41 PM
prinny
Nov 22, 2015 11:07 PM
