Neg. Camber on stock height = Gayness
Old Jun 4, 2009 | 05:12 PM
OnE BaD G35's Avatar
Whats up everyone. After searching my behind off i decided to post a new thread and see if you guys can help me out. My coupe has never been dropped but for some reason the rear driver side wheel has a very noticable amount of neg camber. It doesnt really bother me much other than it not being normal and that side of the car being alot lower than the other sides. Anyone know what gives? Im not sure if it matters but i have oem 18's all around. Thanks alot guys in advance and if pictures are really really needed then ill make sure to post some. Thanks
Old Jun 4, 2009 | 05:17 PM
MikeYo's Avatar
Your car came with neg camber just like everybody else. Unless your alighnment is messed up, your only running -1 degree max. I'd like to know how that's obvious to your eye... I run -4 degrees rear and that's what I'd call noticeable camber
Old Jun 4, 2009 | 05:20 PM
Ok i have to be having an alignment problem then because the neg. camber on that one wheel is very noticable. My car seems to lean to the left rear corner because the camber is so bad. Damn it!
Old Jun 4, 2009 | 05:25 PM
MikeYo's Avatar
I'd recommend a alignment for starters
Old Jun 4, 2009 | 05:26 PM
Alright thanks alot.
Old Jun 4, 2009 | 07:55 PM
redlude97's Avatar
if it is noticeably different, you may have bent the camber arm on that side somehow
Old Jun 5, 2009 | 02:39 PM
ttrank's Avatar
Grocery getter
Have you had it checked yet? Most shops do a free check.
netcbc
Steering & Suspension CDN
Jul 24, 2015 11:25 AM
nascarbuff17
Jul 16, 2015 10:23 AM
