Vibration Problem from 65-80... Please help
Old Jun 10, 2009 | 11:40 PM
tran2000's Avatar
Just about two weeks ago my car has started to vibrate a good bit when driving on the highway. The vibration is only noticeable from 65-75 ish. at 80 it doesn't vibrate. I thought it was the 19 inch coupe rims i had so i switched them out to M45 19 rims and they still vibrate. So i decided to get the M45 rims balanced. I had them do a High Speed balance on the car and the shaking still persists. So at this point I took My coupe rims and put it on my brothers G35 and they don't vibrate at all. So I KNOW for a fact thats it's my car and not the rims and tires. now i'm trying to figure out if the compression rods can cause the car to vibrate at those speeds because i do have the creaking noise when going over speed bumps and turning left and right so i know my driver side compression rod is messed up.
Old Jun 10, 2009 | 11:54 PM
godmans's Avatar
Your next bet would be 1) wheel bearings 2) brake rotors
GL
Old Jun 11, 2009 | 12:14 AM
tecni's Avatar
Where are you located? We have a tool that picks up vibrations on the car and tells you where its coming from.
Thebaws11
Jul 2, 2021 11:36 AM
itgogitrev
Sep 23, 2015 07:08 PM
mattdg35
Sep 14, 2015 11:28 AM
UndyingDest
Drivetrain
Sep 7, 2015 12:49 AM
