3rd brake light resolution
Old Jun 15, 2009 | 09:35 PM
fleishelja's Avatar
I guess this might qualify as brakes. Well after a lot of frustration with the fact that a replacement 3rd brake light is outrageously expensive I decided to make my own. I used 20 5mm 15,000k leds, all with their own 510 ohm resistor wire in parallel, soldered onto a piece of perfboard I cutout to the same size as the back of the reflector. I then cutout the reflector and epoxied the board to the back of the leftover mount. total circuit draw is .5 amps. Ive been using it for 2 months now with no problems. what do you all think?
Old Jun 15, 2009 | 09:53 PM
erklep's Avatar
looks good
Old Jun 16, 2009 | 12:12 AM
codeflux's Avatar
looks like a perfect match for your tail lights. what happened with your OEM light?
Old Jun 16, 2009 | 07:05 AM
fleishelja's Avatar
It had burned out, so I read on here that sometimes an LED goes bad or a diode will go bad. so I first replaced the bad led and it worked for about a week, then the diode went bad. I think at that point I just said screw it and made my own. I sure as hell wasnt about to shell out 100 bucks for 5 leds, a resistor and a diode.
Old Jun 16, 2009 | 07:38 AM
JOKER's Avatar
CLUB MODERATOR
do you have a midget pressing the brakes?
Old Jun 16, 2009 | 05:41 PM
fleishelja's Avatar
no haha, I stuck one of my tennis rackets I had in the trunk in between the pedal and seat.
Old Jun 16, 2009 | 05:52 PM
tbrillz35's Avatar
haha, I was going to ask if they were ducking down for the picture
mike730
Jan 12, 2018 04:25 PM
Ednica87
Sep 5, 2015 02:59 AM
carid
Group Buys-Vendor
Aug 7, 2015 12:17 PM
Lsantana757
Jul 20, 2015 09:08 AM
