Can I fully drain brake oil?
Old Jun 23, 2009 | 12:46 AM
hyunkoon's Avatar
When I want to change brake lines to stainless steel one, the brake oil will drip all the time.
So can I just fully drain brake oil and flush it after I finish changing brake lines?
Thanks!
Old Jun 23, 2009 | 01:12 AM
tonke73's Avatar
Keep that stuff from hitting your paint. Brake fluid will corrode your paint.
Old Jun 23, 2009 | 05:07 AM
oyoquem's Avatar
Theres no need to drain it. If it leaks that's fine just do a good flush when you are done. If you let it fully drain its going to be more of a pain to get all the air out.
Old Jun 23, 2009 | 09:21 AM
hyunkoon's Avatar
So the oil would not drip that much?
Is it ok to just ignore the oil and replace brake lines?
Thanks!
Old Jun 23, 2009 | 04:27 PM
oyoquem's Avatar
Thanks!
Its going to drip, mainly the fluid in the lines you are removing. Make sure you put an oil pan under to catch the fluid. Make sure you clean it off any paint immediately. Leave the master cylinder reservoir cap on so that the fluid does not flow much while you are doing the swap. Im assuming you have the proper tools to change the lines and know how to flush/bleed the brakes.
miata007
Aug 17, 2015 04:36 PM
wuppiedog
Aug 7, 2015 11:16 AM
EliteG
Engine - Electrical
Aug 5, 2015 07:50 PM
kinetek
Aug 3, 2015 04:25 PM
