sway bar installation
Old Jun 28, 2009 | 01:18 AM
RaginRaj11's Avatar
I just picked up a set of eibach sway bars but they only came with the bushings. Can i use my stock hardware to mount these or do i need to order the hardware kit from eibach?
Old Jun 28, 2009 | 01:33 AM
Swivel's Avatar
Moderator
No direct experience with Eibachs, but it's that way with the Stillens, you use the stock hw.
Old Jun 29, 2009 | 05:43 PM
FenixL1P's Avatar
used stock hardware with the stillens on mine.
Old Jul 1, 2009 | 02:15 PM
tblazing's Avatar
i thought the eibachs came with both bushings and collars
Old Jul 1, 2009 | 02:41 PM
neal@tirerack's Avatar
PLATINUM SPONSOR
When I installed mine they only came with new bushings. Used the stock brackets.
Old Jul 1, 2009 | 04:02 PM
tblazing's Avatar
do you have to upgrade the end links if you are not dropped?
Old Jul 1, 2009 | 04:05 PM
PLATINUM SPONSOR
I didnt have to. Dropped the car after I had the sways installed. Did the sways myself. The exhaust will have to be dropped to put the rear bar on.
Old Jul 1, 2009 | 04:12 PM
tblazing's Avatar
what year G do you have i heard the 05+ have "beefier" end links
Old Jul 1, 2009 | 04:15 PM
PLATINUM SPONSOR
I had an 03 6MT. Showing the sway bars are the same part numbers for 05's though. No notes on the bars for 05 saying new end links will be needed.
Old Jul 1, 2009 | 04:16 PM
tblazing's Avatar
what stiffness do you recommend for F/R for a DD
Old Jul 1, 2009 | 04:20 PM
PLATINUM SPONSOR
Had mine set soft setting front (still stiffer than oe) and medium rear.
Old Jul 6, 2009 | 06:57 PM
tblazing's Avatar
Just got my eibach sways today and for the front sway bar which hole is the softer setting
Old Jul 7, 2009 | 07:20 PM
tblazing's Avatar
bump
jsimonk
Dec 22, 2023 03:49 PM
rezendvous420
May 31, 2020 01:26 PM
zoop425
Mar 29, 2016 05:51 PM
linedr89
Aug 17, 2015 05:11 PM
wuppiedog
Aug 7, 2015 11:16 AM
