stripped caliper slide pin.
Old Jul 7, 2009 | 05:47 PM
TurTLe*'s Avatar
I did my rear brakes. first side went like cake then i go to the other side and found the someone tried and rounded off a good part of the lower caliper sliding pin. I've tried to get with the 14mm wrench and attempted to fit a 13mm since it was around rounded. So i gave up on it due to the lack of clearance and everything. I went around it to get to my rotor and finished the job. with the torque member off i can easily attempt to impact it off or just live with it.
At first i was dead set on replacement but then i looked and kinda thought bout it. how much damage can this cause? I lubed up the pin and it goes in great. I dont thing this really effects much other then the fact that i cant take it off but the only reason why i need to take it off is because i'm doing brakes and even then i really didn't need to bother with the lower one because i could of easily done with just out it.
Would this lead to a FROZEN pin?
seagrasser
May 3, 2022 09:43 AM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
Visionnn
Oct 3, 2015 05:16 AM
dcsbh1
Oct 1, 2015 03:15 PM
NJ6MT
Sep 10, 2015 08:40 AM
