g35 sedan suspension question
Old Jul 19, 2009 | 03:54 AM
lerk's Avatar
Will buying a g35 coupes OEM struts and springs lower my g35 sedan significantly and will the struts/springs fit directly on to a non sport suspension. thanks
Old Jul 19, 2009 | 03:58 AM
CandlestickPark's Avatar
ill Sedan
No it will not lower your sedan significantly, only ~0.5 inches. The coupe suspension is a direct bolt onto a sedan (as is the Z suspension which will lower you ~1 inch)
Old Jul 19, 2009 | 04:35 AM
az1anbeethoven's Avatar
i have a complete set of 2006 revised suspension from a 350z with less than 10k miles in perfect condition...great for lowering 1" all around...$200 bucks plus shipping...let me know
Old Jul 19, 2009 | 07:58 AM
Texasscout's Avatar
You may want to consider using Coupe springs in the back. I have a set I havn't put on yet, but most say that you get a more level look out of it. Mine is a bit lower in the back than the front with the Z springs all round.
Old Jul 19, 2009 | 03:05 PM
lerk's Avatar
I was told since I do not have the sport suspension (red) that I would also need to buy shocks/struts. Is that true?
Old Jul 19, 2009 | 03:09 PM
Texasscout's Avatar
I will say this, the shocks won't last long. Mine went a year and the backs were leaking like a sieve. I slapped on a set of TOKIKO D-specs and never looked back.
Old Jul 20, 2009 | 12:23 PM
RADIOGUY21's Avatar
full revised Z suspension will give you a nice even drop, about 1" in the front and about 1/2" in the rear. You will need to swap out your non-sport struts/shocks since they are not matched handle the stiffer spring rates.
Jusseth
Sep 13, 2020 12:25 PM
rezendvous420
May 31, 2020 01:26 PM
netcbc
Exterior - Body Parts CDN
Aug 21, 2015 09:50 AM
kinetek
Aug 3, 2015 04:25 PM
laksjd84
Jul 24, 2015 05:12 PM
