camber alignment problems???? HELP
Old Jul 21, 2009 | 09:05 AM
cmthresher's Avatar
Lightbulb camber alignment problems???? HELP
i have lowered my car last year with Eibach springs and got the front upper control arm. and rear camber arm.
Well now almost a year later my front tires are REALLY wearing out bad on the inside. The alignment place said that it is the closest they can get it. They have the Camber as far as close as they can get it with still having the toe in....
What can i do about this. I only have 8000 miles on the front tires and they are really wore out bad (on the inside). I am gonna have the tires swapped from left to right front.. since my factory 18's are offset..
Was just hope'n that i could get this problem fixed. and that someone knows of something that i can do.. I can't keep on going through tires every 10,000 miles..
Thanks
Old Jul 21, 2009 | 10:56 AM
redlude97's Avatar
What front camber arms do you have? What are the actual alignment settings? They should provide you with a printout
Old Jul 21, 2009 | 11:31 AM
cmthresher's Avatar
i have a front camber kit from eurosportgarage.. i am waiting back from them to find out what the specs are for it. If you know please let me know.. I am thinking i am going to have to buy a eibach pro align kit for the front and just sell these old ones.. wow this sucks.. wasted money
-1.5 and -1.2 were the best settings that they could bet with still having the toe in ...
so i need another whole degree to get my car within specs.. any suggestion?????????????//
Old Jul 21, 2009 | 09:06 PM
eurodre's Avatar
i would suggest cusco front camber arms
Old Jul 21, 2009 | 09:24 PM
redlude97's Avatar
I would suggest getting SPC/SPL/350evo camber arms. NOT Cusco if you need more positive adjustment
Old Jul 21, 2009 | 09:26 PM
eurodre's Avatar
i heard people have had problems with the spc up front due to the spacers that are in them or something like that
Old Jul 21, 2009 | 09:31 PM
redlude97's Avatar
You don't have to install the spacers. SPC is the only brand of front camber arms that has more than 1 degree of positive adjustment with the spacers. Every other company is limited by the space in the wheelwells. So if you are looking for the most positive adjustment, SPC is the only way to go
Old Jul 21, 2009 | 09:32 PM
eurodre's Avatar
oh o thats the reason i didnt get spc because i heard of the problems associated with them
but yah not to take anymore from the OP
there you go
Old Jul 22, 2009 | 07:06 AM
cmthresher's Avatar
thanks i will check them out.. appreciate the help.. i still havent heard from the company i have the originals from. All the websight says is up to -4degrees.. so i am thinking that even the eibach will work there since they have +3.5 to -1.5 but i wll check yours out also.. do you know where i could find either cheap??
Old Jul 22, 2009 | 07:29 AM
j_marinelli's Avatar
Just purchased some SPC Cambers yesterday from THMotorsports. He's a vendor on here. Definitely knows his stuff and can probably work you a good deal. He did create a thread just for these camber kits to help people out. spc-camber-kit-help-center-thmotorsports Just throw a PM his way.
Old Jul 27, 2009 | 08:33 PM
cmthresher's Avatar
thanks for your help. i ordered the Eibach. i never heard back from the company that i ordered my originals from. I think they are more for a track.. Hopefully this fixes my problems. Ebiach's should be in anyday.. then install and alignment this weekend!!
Z1Motorsports
Suspension-Vendor
56
May 31, 2020 01:56 PM
Soumilg
Jul 23, 2015 09:26 AM
beevanhuynh
Jul 23, 2015 01:37 AM
Soumilg
Jul 18, 2015 12:33 PM
