Alignment question
Alignment question
OK I searched and couldn't find any relevant info:
I have an 06 coupe completely stock, I just got it aligned today after having to replace a ball joint and tie rod end. The front camber is left: -1.7deg and Right:-1.9deg. Is this typical? I have had problems with tire wear on the inside edges. Everything else on the front is in spec.
For a stock coupe, that's way off.
What was the reason you had to have a ball joint and tie rod end replaced?
Speaking to you as somone that posted you have inner tire wear problems. You need to make sure toe is set correctly in the short term.
Front 1mm toe in
Rear 1.5mm toe in
In the long term, you need to get those camber numbers down. Get them down to -1.3 or -1, front and rear, keeping your toe in no lower then posted above.
Front 1mm toe in
Rear 1.5mm toe in
rezendvous420
May 31, 2020 01:26 PM
