Nut Size that Holds Rotors??
Old Aug 2, 2009 | 09:08 PM
G35m@'s Avatar
Need Axle Nut Size that Holds Rotors??
Who can tell me the size of the large nut that holds the the plate behind the rotors (I know that it's larger then 1 1/8")? I need to remove this so I can replace one of the studs that has sheered off. - Thanks
Old Aug 2, 2009 | 09:26 PM
GLuXuRy's Avatar
front is a 22mm
Old Aug 2, 2009 | 09:30 PM
G35m@'s Avatar
need Rear - I should have been more specific
Old Aug 5, 2009 | 09:42 PM
G35m@'s Avatar
32MM for ayone who ever does a search and needs this info -
Old Aug 7, 2009 | 10:21 PM
FenixL1P's Avatar
just use a gear puller to push the sheared stud out...
Old Aug 9, 2009 | 09:48 PM
jhurst's Avatar
To the OP: the bolt sizes are going to be metric.....these cars are Japanese. I recently had to swap out a broken stud, had no problems pushing it out without removing the plate, might try spraying some PB Blaster on it first.
StreetStandard
Wheels & Tires-Vendor
80
Aug 30, 2016 01:21 PM
marsman328
Northern California
Aug 11, 2015 07:29 PM
Cam_Cooper3
Intake & Exhaust
Aug 10, 2015 07:04 PM
Cam_Cooper3
Aug 4, 2015 01:53 PM
