Stock G35 coupe Sport suspension vs. Tein S-tech
Old Aug 6, 2009 | 11:26 AM
jyc18's Avatar
Did any of you lowered your coupe that originally came with sport suspension (sports package)? I really like how my G35 handles with the original sport suspension, but would love to lose about an inch all around. I'm looking into putting tein s-tech + camber kit, and would like to know if it will handle as well or better than the original ones.
Old Aug 6, 2009 | 12:02 PM
mcfly129's Avatar
good question looking to find out the same thing! have you researched the camber kit's yet? if you have what camber kits do you suggest so far?
Old Aug 8, 2009 | 01:38 AM
Gtrpnoyracer's Avatar
i would go spc front control arms and rear camber and toe bolt kit.... i have the tein s techs on as well
Old Aug 9, 2009 | 02:20 AM
Gsedan35's Avatar
Your looking at the wrong S-tech, you will not get what you want.
Your oem spring rates
314/427
Tein S-tech G35 coupe 1.2”/.9” (fronts are progressive, rears are linear)
Spring rates in LBS 358/274 (final rates only, softer intial front progressive rate unknown)
This is the S-tech kit to get to get what your after. Much better spring rates.
Tein S-tech 350Z springs 1.2“/1.1“ drop on G35 coupe (fronts are slightly progressive, rears are linear)
Spring rates in LBS 386/402 (estimated front intial rate is 327lbs
Old Aug 9, 2009 | 02:22 AM
Gsedan35's Avatar
Camber kit recommendaton
SPL or Cusco front
SPL or SPC rear (camber arms AND elongated toe cam bolts).
Old Aug 9, 2009 | 02:42 AM
jayk's Avatar
Regarding front camber kits I don't think it's really nessary. I for sure got the spc rear and did the springmout mod.... Just get a good alignment and you're good.
Old Aug 9, 2009 | 03:31 AM
Xet's Avatar
Xet
its necessary if you go s-tech, especially 350z
you can barely squeeze by with z htechs... and not everyone can.
Old Aug 12, 2009 | 03:26 PM
jyc18's Avatar
Thanks. I've been doing alittle research myself and I do agree with you. Now I'm thinking, with the springs, new shocks(most likely needed), and camber kit, it would be better/easier to go with coilover. I know it costs more, but if I add up all the things I needed to get springs done the difference wouldnt be that great. Not to mention better result.
Old Aug 12, 2009 | 05:50 PM
irishsig's Avatar
Your only other option would be to go 350Z h-techs and then do the rear spring mount mod.
Then just slap on the rear spc camber kit.
The front still might be in spec with the h-techs.
But if u have the cash u can go the coilover route.
Old Jul 22, 2010 | 12:43 PM
or_G's Avatar
any idea how much of a drop Revised 350z springs will give me on a sports suspension coupe?
jimNC
Jul 25, 2015 05:47 AM
netcbc
Steering & Suspension CDN
Jul 24, 2015 11:25 AM
crazy_g35s
Jul 20, 2015 02:30 PM
