I've got Zeals! Couple of Q's...
Old Aug 13, 2009 | 01:20 AM
blazinasian's Avatar
Hey everyone! Just got some Zeal Function Xs coilovers with the rear true coilover setup. I also picked up a set of Battle Version camber arms and toe links. I just got a few questions and was hoping ya'll could help me out before I install. This is my first foray into suspension components so forgive the newbness
Question 1: This coilover setup is independently height adjustable, both front and rear(?). When I raise or lower the car, is there anything else I have to adjust on the actual coilover? I should be able to just raise or lower without having to adjust the dampening or spring tension right?
Quetion 2: Well I've read through lots of the DIY's for this install and I'm pretty confident I can do it. During the install, is there anything tricky or special that is more specific for my Zeals compared to other 'standard' setups? I don't have to 'pre-load' anything right? A straight forward swap from old to new?
Well I might have some more Q's later on, but these are some of the main concerns I have right now. Thank you all for any help and suggestions !
Take care
Old Aug 13, 2009 | 01:25 AM
martyg35's Avatar
straight foward install but you would have to drill small holes into the trunk/wheel well area for the extended rear dampening adjusters
Old Aug 13, 2009 | 02:10 AM
Hey Marty! One of the few people I hoped would chime in! Thanks for the tip! I've got the adjusters, but not sure how to install them onto the rear coilovers. Instructions in Japanese= FAIL for me since I know 0% Japanese letters. It looks like I've got to unscrew the current dial to connect the adjusters...
Take care
KallDay86
Jan 8, 2016 12:42 AM
prinny
Nov 22, 2015 11:07 PM
AL8782
Oct 3, 2015 10:26 AM
Visionnn
Oct 3, 2015 05:16 AM
hrdwirk1
Oct 2, 2015 06:34 PM
