GT Spec strut bar and brake question
Old Sep 2, 2009 | 05:33 PM
foxx_good's Avatar
I just installed the gt spec strut bar and i have a question on the driver's side the bracket that bolts to the strut was essentially touching the brake lines is this how its supposed to be? Should i be concerned about this?
Old Sep 2, 2009 | 06:14 PM
bigc's Avatar
Wings Nation
i think you're referring to the A/C lines (the soft aluminium ones that are kinda shiny). if so, you can bend those lines a bit to provide some clearance. just go slow.
Old Sep 2, 2009 | 06:21 PM
foxx_good's Avatar
no its for sure the brake lines the black ones coming off the master cylinder side the ac line have enough its just one of the brake lines is right on it i will post a picture when i can
Old Sep 2, 2009 | 06:43 PM
bigc's Avatar
Wings Nation
gotcha, i think you're referring to the single black line that comes out of the top, center of the brake compartment. hmm, its odd that its in the way of the STB bracket - mine bends up away from the strut tower bolts and towards the engine. IIRC, the line is very stiff so I'm not sure how you'd bend it...awaiting pix
jsimonk
Dec 22, 2023 03:49 PM
North NJ G
Steering & Suspension
12
May 27, 2023 01:14 AM
Th611
Oct 27, 2015 03:48 PM
EnCr1pt3d
Jul 29, 2015 03:35 AM
