So 350z springs are all I need to lower the car?
I have a couple of questions:
1: if i want to lower my car, are the springs all I need? I've bee told that I would need some spacers too ?
2: I've had problem with rear wheels rubbing the fender after I changed to 19" rays. but problem solved after I rolled the fender. I wonder if the rubbing will re-occure again after i lowered the car?
thank you
thank you
I wouldn't run z springs on non sport sedans. The ride will be sacrificed quite a bit. I would use the z springs and shocks together, revised setup. Can be purchased for 2-300 dollars at most. If the fender roll solved the rubbing, it shouldn't rub when you lower it as the suspension still travels the same direction and lowering it will actually give you more negative camber.
Unless he's running very wide tires, like 265 or greater. OP, you don't need spacers, in fact you should be nice and flush with your Rays. And yes, use the Z shocks as well.
How about some pictures?
I used the 350Z Unrevised springs. The back sits a bit lower than the front, but I have a set of Coupe spings for the back that should take care of that.
Some before and after pics:
Before the Drop:
After and with new wheels/tires:
