camber adjustment and alignment...
i have bc coilovers and recently just raised it cause the guy couldnt get it close to specs cause the car was way too low. so i raised it and brought the car in and he still couldnt get it close so he suggested a front and rear camber kit. ive been searching for kits that sell front and back and found this...
http://www.autocarparts.com/part/1676/131/
its pretty cheap and i would have the front camber adjustment and the rear camber and toe adjusment. also would this be all i need for the alignment to get my car close or back to stock specs? any other kits out there for a good deal or jus plain better lmk thanks!
To OP, just get SPC front and rear camber kits; make sure your fronts are the revised version for the G35 coupe and you won't have any problems with ABS sensor knock. They are the best trade-off between quality and price, I have them and they work perfectly.
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
