2003 G35 sedan Front Brakes Noise
Old Sep 29, 2009 | 05:11 PM
pinky1121's Avatar
Hi,
I just recently replace my front rotor and brake pads with original parts from Infiniti dealer, but after it is installed i started to exhibit this groan noise when i brake and slowly to a complete stop. My machcanic told me that i need a hardware kit for the front brake, which is this part# 410805Y725, after this part is installed it will make the noise go away, i am just wonder did anybody experience this before. supposely its metal plates that covers the brake pads and can reduce or eliminate the noise the brake pad and rotor makes. Any insight will be great.
Thanks
Tony
Old Sep 29, 2009 | 05:19 PM
Jeff92se's Avatar
Red Card Crew
You could avoid that by cleaning and properly lubing the existing brake parts. The noise is the pad vibrating back/forth in the hardware kit IMHO. Cleaning the points where the pad "ears" slide back/forth and lubing them with high temp grease usually fixes this.
Old Sep 29, 2009 | 05:29 PM
5150DS's Avatar
Originally Posted by pinky1121
Hi,
Thanks
Tony
He is alking about the brake shims, the new pads should have come with them. If they did not he should have put them on your new pads from the old ones.
Old Sep 30, 2009 | 12:18 PM
pinky1121's Avatar
Yeah but i lost mine during a previous time doing the brakes, so the brake shim is a must to reduce or get rid of this noise huh? Its just i have to spend another $60~$80 to get factory shims to place on my brakes so it would stop making this groan noise. So frustrated, i been spending alot time and money and i just cant get things done.
Old Sep 30, 2009 | 09:24 PM
G35sedan03's Avatar
whoever replaced your brakes screwed you, they should have used the shims from the old pads. try going to a junk yard and getting them there, it will be way cheaper or swinging by the infiniti dealer and walk to the back and ask the mechs if they can hook you up with a set they just replaced on a vehicle. it's a long shot, but worth trying.
Old Oct 1, 2009 | 06:07 PM
pinky1121's Avatar
Yeah i did feel like i got screwed, but what can i do whats done is done, and this brake noise is annoying the hell out of me right now. So the shims should be able to fix this problem right? I mean the noise i heard is horrible, i do plan to get the brake shims i hope it will help, it should right?
Old Oct 6, 2009 | 07:34 PM
pinky1121's Avatar
Finally got the brake shim installed, and all is well now. no more horrible grinding noise when i brake now. Thanks for all the info and support.
Hasanbaloch
Feb 29, 2024 08:45 PM
Augy
Steering & Suspension
Sep 8, 2015 12:53 AM
wojowojo16
Jul 27, 2015 09:57 AM
Tom_P
Jul 24, 2015 04:05 PM
