Rear Camber arms
Rear Camber arms
Im about to change out the rear camber arms and my question is if do I have to lift the car and have the wheels in mid air or can I just back up the car on some ramps I have? May sound like a stupid question but I dont wanna jack it up beacuse its a bitch. The car is to low to slide a jack and especially jack stands.
Drive up on some thin boards then jack it up
Didnt have to enlarge any holes. I bought a new kit and it didnt have instructions
I just got done installing mine... but the RR doesnt seem right. Its like its toed in way too far. I took it for a ride and its like when I turn back and forth the rear of the car has slop in it.
Anyone else have this kit and have troubles?
Yes you need to elongate the toe bolt holes. It's not optional. If you don't they don't work and you won't get into spec on the toe. It's an easy dremel job on a non ras car, a little harder on an ras car. non ras it's grinding aluminum. ras it's steel. same procedure, different bits to cut it.
sorry wrong. the spc kit and the ichiba kit are identical except the ichiba is red powder coat and the spc is black.
easy to get at just make sure you put them in the right place. The arms usually come with the toe bolts stuck in the end of them. They don't go there. They don't go on the camber arms at all, they go end of the spring buckets.
look here:
http://www.batit.com/forumpics/spctoeboltinstall.pdf
look here:
