ABS pump- need HELP pls.
Old Oct 30, 2009 | 11:14 AM
PetrK's Avatar
Hi, I need help. I have 2005 G35x and I think the ABS pump went bad. What happened.....when you drive on highway 65-75 MPH then you slow done, hit the brake, the whole car start shaking like the rotors are bad. I put new rotors, but the problem is still there. Then you stop, start the car again and car drive normaly. After few miles..same problem again. So I think the ABS pump or ABS computer is bad.
Now...is possible, the problem is really ABS pump? And if, anyone has idea where to send tha pump to fix it? Anyone had same problem?
Thanks a lot to help me with this problem.
Old Oct 30, 2009 | 11:30 AM
Jeff92se's Avatar
Red Card Crew
Odd. No error codes?
Old Oct 30, 2009 | 12:01 PM
ttrank's Avatar
Grocery getter
Pull the ABS fuse and drive it to see if the problem goes away.
Old Oct 30, 2009 | 12:22 PM
PetrK's Avatar
I do not have a scanner, so have no idea if any erros codes are on. But no check engine light.
The fuse is together with the main fuse. So is unpossible to take the fuse out. But I may be mistaken.
Old Oct 30, 2009 | 12:25 PM
ttrank's Avatar
Grocery getter
What "main" fuse?
You can pull the ABS fuse. I have done it many times before. It will kill the ABS and traction control.
Old Oct 30, 2009 | 12:41 PM
PetrK's Avatar
Ok, the fuse is together with ignition switch.(not a main) Is a big fuse....3 in 1.
Old Oct 30, 2009 | 03:18 PM
PetrK's Avatar
I cut off the two 30AMPs for ABS. I drive the car, but the problem is still there. What else could be?
Old Oct 30, 2009 | 03:24 PM
Jeff92se's Avatar
Red Card Crew
Perhaps some of your suspension bushings are really bad. Or a bad wheel bearing?
Old Oct 30, 2009 | 03:40 PM
PetrK's Avatar
This problem is with the brakes, I don't know what...but 100% brakes problem. I checked complete suspension, I did change front swaybar links, and all around is good. Wheel bearings are good too. They don't makes any noises.
Old Oct 30, 2009 | 03:55 PM
str8dum1's Avatar
my abs does the same thing. i think it might be a bad controller.. I dunno either though... makes me crazy
Old Oct 30, 2009 | 04:04 PM
PetrK's Avatar
ABS control unit? You think, the control unit is bolt to the ABS pump? Or somewhere else? Makes me crazy too...
Old Oct 30, 2009 | 08:16 PM
ttrank's Avatar
Grocery getter
When you got new rotors, did you get new pads too? Still sounds more like a problem with the rotors or pads to me.
Old Oct 31, 2009 | 06:45 AM
Q45tech's Avatar
When owners and mechanics finally create enough problems, the solutions are usually found during the every 90 day visit to certified experienced technicans.
Thebaws11
Jul 2, 2021 11:36 AM
jilljann1
Jul 21, 2020 08:12 AM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
Thebaws11
Nov 30, 2016 12:54 PM
miata007
Aug 17, 2015 04:36 PM
