Spc?
Old Oct 31, 2009 | 10:36 AM
GBoy's Avatar
Spc?
Looking to buy front camber kit for 03 sedan, is there any issues with the above.
Thanks
Old Oct 31, 2009 | 12:06 PM
tragedycat's Avatar
Nope, been running mine for 7k miles now without a single problem. I believe the ABS knocking issues were only pertinent to coupes, and they fixed that problem with the revised camber arms anyway.
Old Oct 31, 2009 | 02:06 PM
GBoy's Avatar
I was looking at a used set..
Old Oct 31, 2009 | 02:07 PM
Calvin's Avatar
Overglorified Altima
Yes, it was only a problem for coupes. No, they did not remedy the issues 100% (not even with the revised versions).
Old Oct 31, 2009 | 02:16 PM
tragedycat's Avatar
Didn't know that, I bought revised SPC arms and have never had a problem with them. That's too bad though...
Old Oct 31, 2009 | 02:49 PM
GBoy's Avatar
So I should be good to go with my sedan, I wonder if I need the spacer
I'm only looking for 1 degree..
Old Oct 31, 2009 | 03:09 PM
Calvin's Avatar
It's hit or miss with coupes. Depends on how stiff your suspension is and how low you are.
OP will be fine with his sedan.
Old Oct 31, 2009 | 03:10 PM
Calvin's Avatar
You do not need to install the spacers. The spacers add a static positive 2 degrees.
Old Nov 1, 2009 | 08:27 AM
GBoy's Avatar
Thanks guys..
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
Picture Share
Feb 4, 2018 12:41 PM
bigmike
Sep 17, 2015 01:58 PM
