Brake Pads
Old Nov 29, 2009 | 02:04 PM
bocatrip's Avatar
Originally Posted by SVTCOBRA
Bought my 04 Coupe used and the dealer had put Nissan pads at the corners.
It started squealing like a pig!!!
Put Akebono pro-act on the front and no more squealing!!!
Have been pleased so far.
+1 Great pads, cheap price, very little to no dust, absolutely no squealing, and long lasting.
Old Nov 29, 2009 | 03:24 PM
SER-G35's Avatar
Project Mu B-Force Pads FTW...I love mine
Old Nov 30, 2009 | 07:00 AM
Fri Guy's Avatar
I'll have to look into these Akebono pro-act pads.
Has anyone used the Wagner Thermo Quiets?
Old Nov 30, 2009 | 09:09 AM
Fri Guy's Avatar
I looked into there street pads & they are over $100 for the fronts.
Old Nov 30, 2009 | 01:35 PM
Fri Guy's Avatar
What are the shims that I always hear/read about?
Old Nov 30, 2009 | 02:22 PM
jardoeli's Avatar
I checked them out and I see they are ceramic pads. Do our Gs come with rotors that are "compatable" with ceramic pads? I have my stock rotors (2006 G Coupe) so I'm not sure if I put the ceramic pads, they will wear through the rotors much faster (or not)
Aren't the stock pads semi-metallic?
Old Nov 30, 2009 | 03:21 PM
Fri Guy's Avatar
Which pads are better for daily driving between the Hawk HPS & Akebono Pro Act???
Old Nov 30, 2009 | 07:33 PM
Fri Guy's Avatar
Anyone know which pads would be better between Hawk HPS & Akebono Pro Act?
Old Nov 30, 2009 | 08:26 PM
nghiars's Avatar
the hawks gave me a similar bite to my OEM brembos. good brake pads, minimal dust.
What type of driving do you do? Are you aggressive? cruiser? The pads/rotors you decide to purchase should be based on those questions.
Old Dec 1, 2009 | 07:04 AM
Fri Guy's Avatar
Just normal daily driving. I'm not going to replace the rotors because they are not warped.
Old Dec 1, 2009 | 07:18 AM
JOKER's Avatar
CLUB MODERATOR
go with OEM but not with the ones that came on 03-04, go with the ones that are for 05 and up models.
Most of the aftermarket pads that being suggested here are going to be allot worse. Most of them require better rotors than stock and much hotter temperature to work properly than you can ever achieve during daily driving.
Plus Hawks suck a$$ in wet conditions compared to ceramic OEM pads. And OEM pads are much cheaper.
So if you not upgrading the rotor there is absolutely no need on spending extra money and getting performance pads when you not going to be doing any performance driving.
Get 05 OEM ceramic pads.............and forget about it.
Old Dec 1, 2009 | 04:33 PM
LightsOut's Avatar
SIETESG
05's pads wont fit on 03-04's, since the calipers and rotors are different size.. right?
Old Dec 1, 2009 | 04:37 PM
JOKER's Avatar
CLUB MODERATOR
http://www.infinitipartsonline.com/ shows same part for 03-07 G35 Coupe none brembo.
Check with one of the riverside guys on the forum. They will know for sure.
Old Dec 1, 2009 | 04:56 PM
LightsOut's Avatar
SIETESG
I think maybe the rear will fit but not the front
Old Dec 1, 2009 | 05:50 PM
  #30
bocatrip's Avatar
Correct. The 05 and newer G35s have a larger caliper to correct the premature wear that occured with the 03-04 OEM front pads which were too small for the car. There are no issues with the OEM pads on the 05 and newer G35s. It's the 03-04 cars that suffered from excessive brake dust, and premature wear. I have found the ceramic Akebono Pro Acts which are the same manufacturer as the rear OEM pads on the Coupe work exceptionally well with the factory rotors and eliminate the dust while extending pad and rotor life. It is not a performance pad but works fine for everyday drving.
