Alignment
Old Dec 9, 2009 | 05:13 AM
repin_LB's Avatar
Alignment
Well i got an alignment awhile ago but here are my alignment for the rear, -2.27 camber with .12 toe for the left and -1.99 with .13 toe on the right. I have the SPC camber arms and toe bolt but i was wondering if they should have went alittle lower into spec. THey said this is the closest they can get it but i noticed that the directions say to drill alittle more room for the toe bolt is this true which is why they couldnt get it into spec?
Old Dec 11, 2009 | 02:13 PM
LightsOut's Avatar
SIETESG
for the rear you'll have to drill, as you stated. kit should come with a templet. also, get your alignment some where else, they couldnt even match up your camber and its way off, toe could also use some work.
Dallsinghjr1
Sep 17, 2023 11:25 AM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
MThawkins86
Oct 24, 2015 02:07 AM
Benja455
NorthWest
Sep 23, 2015 01:10 PM
migurus
Sep 5, 2015 09:39 PM
