I purchased a Echiba rear camber kit with toe bolts. The only problem is it didnt come with the template to elongate the toe bolt hole. I was wondering if anyone would be willing to mail me theirs or if there is a website I can download it from. An spc template will work for this as well.
Thanks for the help,
Casey
Casey
GreenGoblin
The goblin resurrection
close
- Join DateOct 2006
- LocationIn my garage
iTrader Positive Feedback100
iTrader Feedback Score(66)
Liked:187 Times in 95 Posts
I think I might still have one, If I do I can fax it to you.
That would be great if you had one. Is there any any way you could email it to me. I dont have access to a fax.
Thanks
Thanks
I also need this template. My email is Drowe303@yahoo.com if anyone wants to send it over
AARONHL
close
- Join DateOct 2007
- LocationɷCONNECTICUTɷ
iTrader Feedback Score(15)
Liked:121 Times in 113 Posts
You pretty much just need to elongate the current hole so the toe bolt can fully turn within the frame (for maximum adjustment). Using a Dremel with a metal cutting bit will work perfectly.
Quote:
Appreciate you sharing this. Saved me $40 bucks!Originally Posted by ntrinsik
Here's the one I sent to the OP.
Here is a good write up on the toe bolt install if anyone needed it.
http://batit.com/forumpics/spctoeboltinstall.pdf
