How to adjust coilovers?
Old Dec 18, 2009 | 09:21 PM
gcoupe_toronto's Avatar
Sorry for the noob question, I have the Stance LX+ coilovers and need to raise it for the winter, my teins on my honda were straight forward and used to take me 10minutes to do, for the G it seems a lil more complicated...
Basically I just need to know how to adjust the rear (they are the oem style) do I just raise the spring collar and not adjust the shock at all? or do I have to adjust both for the rear? I ask this because the shock does not have 2 collars just one so how r u supposed to evenly adjust both shock and spring (I usually would count the rings on my old car)
Any help is appreciated, tried searching but nothing came up!
Old Dec 18, 2009 | 09:29 PM
Gdup35sedan's Avatar
ENVautoDetailing.com
For the rear you need to adjust them the same amount of turns for the spring and shock. If you keep the collar in place after you loosen it, use a piece of tape, then turn the shock. Count the number of threads you adjusted then do the same for the spring. I have the same coils.
-GP-
VatoVazq
Steering & Suspension
16
Jan 3, 2025 11:08 PM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
g.spot
May 9, 2016 10:54 PM
Fox843
Nov 7, 2015 05:43 PM
master111
Sep 25, 2015 08:32 PM
