Just got KWV3, should I install myself or take to dealer?
^The install for coupes and sedans are the same. The rear is the easiest to do....look at the link I posted up above on a spring install. It's basically the same, unless you are running true coilovers (strut in the rear as well) then it's even easier....you just put the strut in and remove the rear spring.
lol...Kris keeps telling me to do it! He's evil for my addiction!
Hey Papa! Did I miss the part on how to remove the rear shocks? How do I remove the top part. I can see how to remove the bottom part, but how about the top mount?
Thanks!
There are 2 12mm nut up on top underneth the car, take those off and the one bolt and that is it for the rear shock.
Yeah I aways thought the suspension was going to be hard, but after doing it once or twice you get it, even if you tackle something else on it, you seem to know what to do.
No I eat good lumpia. I got the name from playing counter strike, it was just lumpia but I usually jump out of corner and kill people so someone said I just got killed by a flyinglumpia, so it stuck.
^I had that problem the first time I put spings in the G. So I went ghetto with it. I bolted the shocks on the bottom with the spring uncompressed then sat on the car to push the spring down so I can tighten the 3 12mm bolts up top. LOL
Could you not push the lower suspension arm up with a jack?
Yeah, I have my eyes on the HKS rear section exhaust.
I am still waiting for the weather to cooperate, I don't have a big garage so I will have to do it outside. Plus my KW suspension is missing the foam isolators for the back.
Hmmm I suppose you can. I didn't think about that, sounds like a better idea. I was frustrated compressing and uncompressing the spring with $8 harbor freight spring compressors for an hour trying to get the bottom to line up so i just said f it and sat on the car.
Yeah, it would be so much easier, it was on the video BytheBay made.
