camber wear?
Old Dec 31, 2009 | 02:12 PM
G35Bandit's Avatar
camber wear?
I recently went to a shop to have rusted bolts removed and I noticed that both my rear tires are bald on the inside...I never would've guessed because the outside still measures out to around 70% tread left. Is this an alignment issue or do I need new rear cambers?
edit: the car is not lowered and the tires have been on the car for about 6k. Like most people I occasionally drive spiritedly but not enough for this kind of damage
Old Dec 31, 2009 | 06:27 PM
urban's Avatar
If you are lowered then you would need a camber kit besides just an alignment. I have lowered mine an inch and a half and have an SPC rear camber kit to get it back into spec.
Old Jan 1, 2010 | 01:13 AM
G35Bandit's Avatar
forgot to mention that it isn't lowered, but thanks for the tip
Old Jan 3, 2010 | 09:55 PM
G35Bandit's Avatar
anybody know whats happening? I'm about to buy new tires and i dont want them to get messed up too =/
Old Jan 3, 2010 | 10:02 PM
CandlestickPark's Avatar
ill Sedan
Get an alignment and make sure that your camber and toe are within spec.
Old Jan 3, 2010 | 10:07 PM
G35Bandit's Avatar
ok, alignment is what I was hoping, new cambers..not so much heh
Old Jan 4, 2010 | 09:03 AM
DailyDrivenCoupe's Avatar
ya with it having the stock suspension on it i would say alignment needs to be done to make sure they are within spec. cambers aren't usually need until modifications are started to the suspension
Marlin84
Apr 1, 2020 12:52 PM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
Picture Share
Feb 4, 2018 12:41 PM
Jeff T
Sep 30, 2015 02:00 PM
