Rear Spring Mounts and a Saggy Rear
Old Jan 12, 2010 | 12:19 AM
AARONHL's Avatar
I've always noticed since I installed lowering springs that my rear wheel gap is different on each side. On the driver side I can barely fit a finger, but on the passenger side I can just about fit two. It's enough of a difference for me to want to fix it.
I looked into the rear spring mount cutting, so I thought if I were to buy new upper and lower spring mounts my springs might sit more even. Could the springs be sitting on an uneven rubber surface? I was wondering if brand new rear rubber spring mounts would solve the problem?
Anyone else have a slightly uneven stance?
Old Apr 23, 2012 | 02:07 PM
uoftguy's Avatar
I have the same issue but I had this from the factory and it carried over after I installed my eibach prokits onto my G35x sedan, 2007. My passenger side rear gap is 1/4" less than the drivers side. I took car to seat the spring on the rubber mounts and the spring cup carefully too. I'm stumped.
Old Apr 25, 2012 | 10:33 PM
Deemo's Avatar
Also have this problem... Had it when I was on coils until I adjusted the other side to compensate. Had it when I was on h&r sport springs, and now i still have this issue on oem springs.
rezendvous420
May 31, 2020 01:26 PM
privatecorye
Steering & Suspension
May 31, 2016 01:56 AM
Duriisimo
Jul 31, 2015 02:21 AM
netcbc
Steering & Suspension CDN
Jul 24, 2015 01:59 PM
netcbc
Jul 24, 2015 11:25 AM
